10-24-2022 02:54 AM
Hi all,
I am getting rib-failure output difference between Cisco IOS 7200 and XR 9000.
7200 router showing bgp routes with r> (rib-failure and best)
9000 router showing bgp routes with *> (valid and best)
For Cisco IOS 7200 series: IP reachability is fine. OSPF is fine. BGP is fine. routes learned with bgp are advertising with r> (rib-failure and valid).
For Cisco XE 9000 series: IP reachability is fine. OSPF is fine. BGP is fine. routes learned with bgp are advertising with *> (valid and best).
Below pic is for Cisco IOS 7200 series routers.
Please see below configuration for PE1, P and PE2
PE1#sho run
Building configuration...
Current configuration : 1331 bytes
version 15.2
hostname PE1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
mpls label protocol ldp
interface Loopback0
ip address 9.9.0.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex full
interface Ethernet1/0
ip address 30.0.0.1 255.255.255.0
duplex full
mpls ip
interface Ethernet1/1
no ip address
shutdown
duplex full
interface Ethernet1/2
no ip address
shutdown
duplex full
interface Ethernet1/3
no ip address
shutdown
duplex full
router ospf 9
router-id 9.9.0.1
network 9.9.0.1 0.0.0.0 area 0
network 30.0.0.0 0.0.0.255 area 0
router bgp 9
bgp router-id 9.9.0.1
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 9.9.0.2 remote-as 9
neighbor 9.9.0.9 remote-as 9
neighbor 9.9.0.9 update-source Loopback0
address-family ipv4
network 9.9.0.1 mask 255.255.255.255
neighbor 9.9.0.2 activate
neighbor 9.9.0.9 activate
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
mpls ldp router-id Loopback0
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
PE1#
PE1#sho ip int br
FastEthernet0/0 unassigned YES NVRAM administratively down down
Ethernet1/0 30.0.0.1 YES NVRAM up up
Ethernet1/1 unassigned YES NVRAM administratively down down
Ethernet1/2 unassigned YES NVRAM administratively down down
Ethernet1/3 unassigned YES NVRAM administratively down down
Loopback0 9.9.0.1 YES NVRAM up up
PE1#sho ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is not set
9.0.0.0/32 is subnetted, 3 subnets
C 9.9.0.1 is directly connected, Loopback0
O 9.9.0.2 [110/21] via 30.0.0.2, 00:14:05, Ethernet1/0
O 9.9.0.9 [110/11] via 30.0.0.2, 00:14:29, Ethernet1/0
30.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 30.0.0.0/24 is directly connected, Ethernet1/0
L 30.0.0.1/32 is directly connected, Ethernet1/0
40.0.0.0/24 is subnetted, 1 subnets
O 40.0.0.0 [110/20] via 30.0.0.2, 00:14:29, Ethernet1/0
PE1#sho ip route ospf
O 9.9.0.2 [110/21] via 30.0.0.2, 00:14:13, Ethernet1/0
O 9.9.0.9 [110/11] via 30.0.0.2, 00:14:37, Ethernet1/0
O 40.0.0.0 [110/20] via 30.0.0.2, 00:14:37, Ethernet1/0
PE1#sho bgp summ
BGP router identifier 9.9.0.1, local AS number 9
BGP table version is 4, main routing table version 4
3 network entries using 432 bytes of memory
3 path entries using 240 bytes of memory
2/2 BGP path/bestpath attribute entries using 272 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 944 total bytes of memory
BGP activity 3/0 prefixes, 3/0 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
9.9.0.2 4 9 19 19 4 0 0 00:14:09 1
9.9.0.9 4 9 19 20 4 0 0 00:14:36 1
PE1#sho bgp
BGP table version is 4, local router ID is 9.9.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 9.9.0.1/32 0.0.0.0 0 32768 i
r>i 9.9.0.2/32 9.9.0.2 0 100 0 i
r>i 9.9.0.9/32 9.9.0.9 0 100 0 i
PE1#
P#sho running-config
Current configuration : 1425 bytes
version 15.2
hostname P
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
interface Loopback0
ip address 9.9.0.9 255.255.255.255
no ip address
shutdown
duplex full
ip address 30.0.0.2 255.255.255.0
duplex full
mpls ip
ip address 40.0.0.2 255.255.255.0
duplex full
mpls ip
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
router ospf 9
router-id 9.9.0.9
network 9.9.0.9 0.0.0.0 area 0
network 40.0.0.0 0.0.0.255 area 0
router bgp 9
bgp router-id 9.9.0.9
neighbor 9.9.0.1 remote-as 9
neighbor 9.9.0.1 update-source Loopback0
neighbor 9.9.0.2 update-source Loopback0
address-family ipv4
network 9.9.0.9 mask 255.255.255.255
neighbor 9.9.0.1 activate
exit-address-family
no ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
P#
P#sho ip int br
Ethernet1/0 30.0.0.2 YES NVRAM up up
Ethernet1/1 40.0.0.2 YES NVRAM up up
Loopback0 9.9.0.9 YES NVRAM up up
P#sho ip route
O 9.9.0.1 [110/11] via 30.0.0.1, 00:15:48, Ethernet1/0
O 9.9.0.2 [110/11] via 40.0.0.1, 00:15:34, Ethernet1/1
C 9.9.0.9 is directly connected, Loopback0
L 30.0.0.2/32 is directly connected, Ethernet1/0
40.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 40.0.0.0/24 is directly connected, Ethernet1/1
L 40.0.0.2/32 is directly connected, Ethernet1/1
P#sho ip route ospf
O 9.9.0.1 [110/11] via 30.0.0.1, 00:15:51, Ethernet1/0
O 9.9.0.2 [110/11] via 40.0.0.1, 00:15:37, Ethernet1/1
P#sho ip bg summ
BGP router identifier 9.9.0.9, local AS number 9
9.9.0.1 4 9 21 21 4 0 0 00:15:53 1
9.9.0.2 4 9 21 21 4 0 0 00:15:38 1
P#sho ip bg
BGP table version is 4, local router ID is 9.9.0.9
r>i 9.9.0.1/32 9.9.0.1 0 100 0 i
*> 9.9.0.9/32 0.0.0.0 0 32768 i
P#
PE2#sh run
Current configuration : 1350 bytes
version 15.2
hostname PE2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
interface Loopback0
ip address 9.9.0.2 255.255.255.255
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
ip address 40.0.0.1 255.255.255.0
duplex full
mpls ip
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
router ospf 9
router-id 9.9.0.2
network 9.9.0.2 0.0.0.0 area 0
router bgp 9
address-family ipv4
network 9.9.0.2 mask 255.255.255.255
exit-address-family
no ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
PE2#
PE2#sho ip int br
Ethernet1/0 unassigned YES NVRAM administratively down down
Ethernet1/1 40.0.0.1 YES NVRAM up up
Loopback0 9.9.0.2 YES NVRAM up up
PE2#
PE2#sho ip route
O 9.9.0.1 [110/21] via 40.0.0.2, 00:16:43, Ethernet1/1
C 9.9.0.2 is directly connected, Loopback0
O 9.9.0.9 [110/11] via 40.0.0.2, 00:16:43, Ethernet1/1
30.0.0.0/24 is subnetted, 1 subnets
O 30.0.0.0 [110/20] via 40.0.0.2, 00:16:43, Ethernet1/1
L 40.0.0.1/32 is directly connected, Ethernet1/1
PE2#
PE2#sho ip route osp
O 9.9.0.1 [110/21] via 40.0.0.2, 00:16:52, Ethernet1/1
O 9.9.0.9 [110/11] via 40.0.0.2, 00:16:52, Ethernet1/1
O 30.0.0.0 [110/20] via 40.0.0.2, 00:16:52, Ethernet1/1
PE2#
PE2#sho ip bgp summ
BGP router identifier 9.9.0.2, local AS number 9
9.9.0.1 4 9 22 22 4 0 0 00:16:41 1
9.9.0.9 4 9 22 22 4 0 0 00:16:53 1
PE2#
PE2#sho ip bgp
BGP table version is 4, local router ID is 9.9.0.2
*> 9.9.0.2/32 0.0.0.0 0 32768 i
PE2#
Please see below configuration for XR77, XR44 and XR66
RP/0/0/CPU0:XR77#show running-config
Mon Oct 24 08:22:50.724 UTC
!! IOS XR Configuration 6.1.3
!! Last configuration change at Fri Oct 21 15:28:47 2022 by misbah
hostname XR77
interface Loopback0
ipv4 address 9.9.0.7 255.255.255.0
interface MgmtEth0/0/CPU0/0
shutdown
interface GigabitEthernet0/0/0/0
ipv4 address 9.9.47.7 255.255.255.0
interface GigabitEthernet0/0/0/1
shutdown
interface GigabitEthernet0/0/0/2
shutdown
router ospf 9
router-id 9.9.0.7
area 0
interface Loopback0
router bgp 9
bgp router-id 9.9.0.7
address-family ipv4 unicast
network 9.9.0.7/32
neighbor 9.9.0.4
remote-as 9
next-hop-self
neighbor 9.9.0.6
remote-as 9
end
RP/0/0/CPU0:XR77#
RP/0/0/CPU0:XR77#
RP/0/0/CPU0:XR77#sho ip int br
Mon Oct 24 08:22:57.553 UTC
Interface IP-Address Status Protocol Vrf-Name
Loopback0 9.9.0.7 Up Up default
MgmtEth0/0/CPU0/0 unassigned Shutdown Down default
GigabitEthernet0/0/0/0 9.9.47.7 Up Up default
GigabitEthernet0/0/0/1 unassigned Shutdown Down default
GigabitEthernet0/0/0/2 unassigned Shutdown Down default
RP/0/0/CPU0:XR77#
RP/0/0/CPU0:XR77#show route
Mon Oct 24 08:23:08.163 UTC
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
U - per-user static route, o - ODR, L - local, G - DAGR, l - LISP
A - access/subscriber, a - Application route
M - mobile route, r - RPL, (!) - FRR Backup path
C 9.9.0.0/24 is directly connected, 00:04:40, Loopback0
O 9.9.0.4/32 [110/2] via 9.9.47.4, 00:03:18, GigabitEthernet0/0/0/0
O 9.9.0.6/32 [110/3] via 9.9.47.4, 00:03:08, GigabitEthernet0/0/0/0
L 9.9.0.7/32 is directly connected, 00:04:40, Loopback0
O 9.9.46.0/24 [110/2] via 9.9.47.4, 00:03:12, GigabitEthernet0/0/0/0
C 9.9.47.0/24 is directly connected, 00:04:36, GigabitEthernet0/0/0/0
L 9.9.47.7/32 is directly connected, 00:04:36, GigabitEthernet0/0/0/0
RP/0/0/CPU0:XR77#
RP/0/0/CPU0:XR77#sho route ospf
Mon Oct 24 08:23:14.932 UTC
O 9.9.0.4/32 [110/2] via 9.9.47.4, 00:03:25, GigabitEthernet0/0/0/0
O 9.9.0.6/32 [110/3] via 9.9.47.4, 00:03:14, GigabitEthernet0/0/0/0
O 9.9.46.0/24 [110/2] via 9.9.47.4, 00:03:19, GigabitEthernet0/0/0/0
RP/0/0/CPU0:XR77#
RP/0/0/CPU0:XR77#sho bgp summ
Mon Oct 24 08:23:21.032 UTC
BGP router identifier 9.9.0.7, local AS number 9
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0000000 RD version: 5
BGP main routing table version 5
BGP NSR Initial initsync version 2 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
BGP is operating in STANDALONE mode.
Process RcvTblVer bRIB/RIB LabelVer ImportVer SendTblVer StandbyVer
Speaker 5 5 5 5 5 0
Neighbor Spk AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down St/PfxRcd
9.9.0.4 0 9 7 7 5 0 0 00:03:20 1
9.9.0.6 0 9 7 6 5 0 0 00:03:18 1
RP/0/0/CPU0:XR77#
Mon Oct 24 08:23:25.301 UTC
i - internal, r RIB-failure, S stale, N Nexthop-discard
*>i9.9.0.4/32 9.9.0.4 0 100 0 i
*>i9.9.0.6/32 9.9.0.6 0 100 0 i
*> 9.9.0.7/32 0.0.0.0 0 32768 i
Processed 3 prefixes, 3 paths
RP/0/0/CPU0:XR77#
RP/0/0/CPU0:XR77#
RP/0/0/CPU0:XR44#show running-config
Mon Oct 24 08:24:35.728 UTC
!! Last configuration change at Fri Oct 21 15:30:54 2022 by misbah
hostname XR44
interface Loopback0
ipv4 address 9.9.0.4 255.255.255.255
shutdown
ipv4 address 9.9.47.4 255.255.255.0
ipv4 address 9.9.46.4 255.255.255.0
shutdown
router ospf 9
router-id 9.9.0.4
area 0
interface Loopback0
router bgp 9
bgp router-id 9.9.0.4
network 9.9.0.4/32
neighbor 9.9.0.6
remote-as 9
next-hop-self
neighbor 9.9.0.7
remote-as 9
next-hop-self
end
RP/0/0/CPU0:XR44#
RP/0/0/CPU0:XR44#
RP/0/0/CPU0:XR44#sho ip int br
Mon Oct 24 08:24:40.208 UTC
Loopback0 9.9.0.4 Up Up default
GigabitEthernet0/0/0/0 9.9.47.4 Up Up default
GigabitEthernet0/0/0/1 9.9.46.4 Up Up default
RP/0/0/CPU0:XR44#
RP/0/0/CPU0:XR44#sho route
Mon Oct 24 08:24:47.867 UTC
L 9.9.0.4/32 is directly connected, 00:05:46, Loopback0
O 9.9.0.6/32 [110/2] via 9.9.46.6, 00:04:55, GigabitEthernet0/0/0/1
O 9.9.0.7/32 [110/2] via 9.9.47.7, 00:05:00, GigabitEthernet0/0/0/0
C 9.9.46.0/24 is directly connected, 00:05:44, GigabitEthernet0/0/0/1
L 9.9.46.4/32 is directly connected, 00:05:44, GigabitEthernet0/0/0/1
C 9.9.47.0/24 is directly connected, 00:05:44, GigabitEthernet0/0/0/0
L 9.9.47.4/32 is directly connected, 00:05:44, GigabitEthernet0/0/0/0
RP/0/0/CPU0:XR44#
RP/0/0/CPU0:XR44#sho route ipv
ipv4 ipv6
RP/0/0/CPU0:XR44#sho route ospf
Mon Oct 24 08:24:57.247 UTC
O 9.9.0.6/32 [110/2] via 9.9.46.6, 00:05:04, GigabitEthernet0/0/0/1
O 9.9.0.7/32 [110/2] via 9.9.47.7, 00:05:10, GigabitEthernet0/0/0/0
RP/0/0/CPU0:XR44#
RP/0/0/CPU0:XR44#sho bgp summary
Mon Oct 24 08:25:04.216 UTC
BGP router identifier 9.9.0.4, local AS number 9
Speaker 5 5 5 5 5 0
9.9.0.6 0 9 9 9 5 0 0 00:05:05 1
9.9.0.7 0 9 9 9 5 0 0 00:05:06 1
RP/0/0/CPU0:XR44#
Mon Oct 24 08:25:08.056 UTC
*> 9.9.0.4/32 0.0.0.0 0 32768 i
*>i9.9.0.7/32 9.9.0.7 0 100 0 i
RP/0/0/CPU0:XR44#
RP/0/0/CPU0:XR44#
RP/0/0/CPU0:XR66#sho run
Mon Oct 24 08:25:29.255 UTC
!! Last configuration change at Fri Oct 21 14:08:08 2022 by misbah
hostname XR66
interface Loopback0
ipv4 address 9.9.0.6 255.255.255.255
shutdown
shutdown
ipv4 address 9.9.46.6 255.255.255.0
shutdown
router ospf 9
router-id 9.9.0.6
area 0
interface Loopback0
router bgp 9
bgp router-id 9.9.0.6
network 9.9.0.6/32
neighbor 9.9.0.4
remote-as 9
neighbor 9.9.0.7
remote-as 9
end
RP/0/0/CPU0:XR66#sho ip int br
Mon Oct 24 08:25:34.705 UTC
Loopback0 9.9.0.6 Up Up default
GigabitEthernet0/0/0/0 unassigned Shutdown Down default
GigabitEthernet0/0/0/1 9.9.46.6 Up Up default
RP/0/0/CPU0:XR66#
RP/0/0/CPU0:XR66#
RP/0/0/CPU0:XR66#
RP/0/0/CPU0:XR66#sho route
Mon Oct 24 08:25:38.445 UTC
O 9.9.0.4/32 [110/2] via 9.9.46.4, 00:05:45, GigabitEthernet0/0/0/1
L 9.9.0.6/32 is directly connected, 00:06:28, Loopback0
O 9.9.0.7/32 [110/3] via 9.9.46.4, 00:05:45, GigabitEthernet0/0/0/1
C 9.9.46.0/24 is directly connected, 00:06:25, GigabitEthernet0/0/0/1
L 9.9.46.6/32 is directly connected, 00:06:25, GigabitEthernet0/0/0/1
O 9.9.47.0/24 [110/2] via 9.9.46.4, 00:05:45, GigabitEthernet0/0/0/1
RP/0/0/CPU0:XR66#
RP/0/0/CPU0:XR66#sho route ospf
Mon Oct 24 08:25:41.454 UTC
O 9.9.0.4/32 [110/2] via 9.9.46.4, 00:05:48, GigabitEthernet0/0/0/1
O 9.9.0.7/32 [110/3] via 9.9.46.4, 00:05:48, GigabitEthernet0/0/0/1
O 9.9.47.0/24 [110/2] via 9.9.46.4, 00:05:48, GigabitEthernet0/0/0/1
RP/0/0/CPU0:XR66#
RP/0/0/CPU0:XR66#sho bgp summary
Mon Oct 24 08:25:47.014 UTC
BGP router identifier 9.9.0.6, local AS number 9
Speaker 5 5 5 5 5 0
9.9.0.4 0 9 9 9 5 0 0 00:05:47 1
9.9.0.7 0 9 8 9 5 0 0 00:05:45 1
RP/0/0/CPU0:XR66#
Mon Oct 24 08:25:50.664 UTC
*> 9.9.0.6/32 0.0.0.0 0 32768 i
RP/0/0/CPU0:XR66#
