11-23-2023 05:35 AM
We recently configured TACACS+ for AD authentication on Cisco switches and it works great. However, when I access the web GUI of these switches, I cannot log in using a domain account, only local users defined on the switch can log in. I tried to configure something like aaa authentication webauth default group TACSRV enable but I am not even sure if this is correct or if any additional config is needed. Would you mind dropping here any suggestions? Thank you!
11-23-2023 05:42 AM - edited 11-23-2023 05:42 AM
Hello @dobhal23
Do you have this on your configuration ?
ip http authentication aaa login-authentication TACSRV
--Configures the web authentication method using TACACS+.
11-23-2023 06:05 AM
Can i see http config ?
Do you config
Ip http auth aaa login-auth <method> ?
