Task Routing with ucce11.5 - SocialMiner and MR issue
ramimakram
I used the deployment and configuration guide for socialminer11.5 to be integrated with ucce11.5 for task routing. In the mean Social miner is added as an external machine on CCE administration web successfully. and all configurations are done. I am facing 2 issues where they might be related:
- SoicialMiner Indexer is not starting
- on the Hardware server status it says "Unsupported deployment profile"
- MR PG is not starting --> Pim logs " (probably related to indexer?)
PG2A-pim1 Peripheral: 5002, sending OPC: PIM_OK_ACK, acknowledgment for command: PIM_CONFIGURE_REQ (Trans ID: 0).
19:52:51:631 PG2A-pim1 Attempting to connect to MR application at IP address: 192.168.1.77, port: 38001.
19:53:21:535 PG2A-pim1 Trace: Node Manager thread received shutdown message
19:53:21:551 PG2A-pim1 Node Manager handler received shutdown message.
19:53:21:551 PG2A-pim1 Requesting normal MDS termination.
19:53:21:661 PG2A-pim1 Connection to MDS process closed.
How can I debug such issue on indexer, what can be the reason this service is not starting. The system automatically enables and completes the CCE Configuration for Multichannel Routing settings so what can be wrong or what needs to be checked?
Your support is highly appreciated.
ramimakram
I decided to go for a server restart after increasing RAM and CPU and this solved the issue.
ramimakram
