Unable to Turn on A Lamp by Using a MCU in Cisco Packet Tracer
grecoandreauni
Well what the title says, I'm able to use an MCU to turn on a LED but when I try the same operation on a Light item, it doesn't work anymore , the way it works should be the same so I don't understand what I'm doing wrong
@grecoandreauni
 You can play with the example I am attaching. You can change the delay parameter to get the effect you want.
thank you for your answer, using the command customwrite instead of digitalwrite seems to fix the issue, sorry for the late answer
