USB Console Cable
hketenc123456
Community Member
I couldn't find the right driver on Cisco support pages.
Which driver software should we use in Win10, for the Cisco USB console cable to connect to the 4G 829 router with a mini USB port?
We installed "CP210x USB to UART Bridge Virtual COM Port" driver, but none of the COM ports worked in PuTTY.
9 Replies 9
luis_cordova
Hi Luis, thanks for your interest and sharing me the link of the driver for the USB console connection.
I just downloaded the .zip from the link to my computer and I will go to the site on the next days to try that.
I will write again if it works for the 829 Industrial ISR, 4G router as well.
Just Perfect!. This is the driver I needed to connect a mini-usb - USB console cable, on a Cisco 1921 router. It Just take a Running the .exe file, and a PC restart (I still use Windows 8.1). Thank you very much Luis!
p oh
You need to update the driver.
For WIn10 , install the setup(x64).exe from the Cisco_usbconsole_driver_3_1.zip.
Check that the Cisco Serial (Comx) is using the correct driver provider which should be Cisco.  Don't use the Cypress driver.
https://i.imgur.com/AXgMVzh.png
To update the driver,
1. If you installed it already and having issues, uninstall it using the setup(x64),exe then reboot PC.
2. First, disconnect the blue Cisco USB console cable. Reinstall the Cisco USB console drive using setup(x64).exe from the Windows_64 folder which was extracted from file Cisco_usbconsole_driver_3_1.zip.
3. Reboot PC
4. Open device manager to observe the driver installation.  Check that you see "Cisco USB to Serial Adapter".  If you don't see it repeat the above steps.
5. if you see above "Cisco USB to Serial Adapter". then
Click UPDATE DRIVER, then Browse my computer for driver software.
6. Choose " Let me pick from a list of available driers on my Computer."  Select "Cisco Serial".
7. Finally,. connect to the COM port x indicated in the Device Manager,  Ports (COM & LPT) , Cisco Serial (COMx)
mahesh-gangarapu
Community Member
Please share the usb to console drivers
Here it is.  For Windows 32 and 64 bit
p oh
For Mac and Linux
fcicco
Community Member
waste of my time need just a drv download from somewhere else or: create 10 min temp account then get verification code then try to download boom you need full address then its login to some page wher you are log off .
Description :Cisco_usbconsole_driver_3_1.zip
Release :3.1
Release Date :04-Dec-2014
FileName :Cisco_usbconsole_driver_3_1.zip
Size :14.35 MB ( 15045453 bytes)
MD5 Checksum :eff2e955edcdc70209e6f9c8f6bd59cd
SHA512 Checksum :7a1
XavierHeard
Community Member
Following these steps helped fix the error "Insufficient system resources exist to complete the requested service" after installing Windows 11 updates. Thanks!
