routing ipv5 with static route
Jose Salazar
Hello
In have 3 routers connected using global ipov6
in router 0, connected to a PC, I have the subnet  2001:db8:d955:1008::/64
between router 0 and 1 serial connection with IPs
2001:ffff:eeee:aaaa::1/64  --> r0
2001:ffff:eeee:aaaa::2/64 --> r1
between router 1 and 2
router1
2001:BBBB:AAAA:EEEE::1/64 --> r1
2001:BBBB:AAAA:EEEE::2/64 --> r2
I can ping from  PC connected to router1 and IP 2001:db8:d955:1008:201:2FFF:FE8D:5E55::/64 to router 1
but I can not ping from router 0 to r1 or r2
I have created static routes
router 0
R0#sh run
Building configuration...
Current configuration : 949 bytes
version 16.6.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R0
no ip cef
ipv6 unicast-routing
no ipv6 cef
no ip domain-lookup
spanning-tree mode pvst
interface GigabitEthernet0/0/0
 no ip address
 duplex auto
 speed auto
 ipv6 address 2001:DB8:D955:1008:2E0:F7FF:FE52:6701/64
interface GigabitEthernet0/0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/0/2
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/1/0
 no ip address
 ipv6 address 2001:FFFF:EEEE:AAAA::1/64
 clock rate 2000000
interface Serial0/1/1
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
ip classless
ip flow-export version 9
ipv6 route 2001:AAAA:BBBB:CCCC::/64 Serial0/1/0
line con 0
line aux 0
line vty 0 4
 login
end
R0#
router 1
R1>
R1>
R1>ena
R1#
R1#sh run
Current configuration : 1007 bytes
version 16.6.4
hostname R1
no ip cef
no ipv6 cef
no ip domain-lookup
 no ip address
 duplex auto
 speed auto
 ipv6 address 2001:5555:7777:AAAA:216:60FF:FE60:A001/64
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 ipv6 address 2001:FFFF:EEEE:AAAA::2/64
 no ip address
 ipv6 address 2001:BBBB:AAAA:EEEE::1/64
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
ip classless
ipv6 route 2001:DB8:D955:1008::/64 Serial0/1/0
ipv6 route 2001:AAAA:BBBB:CCCC::/64 Serial0/1/1
line con 0
line aux 0
line vty 0 4
 login
end
R1#
R1#
R1#
R1#
R1#
R1#
router 2
R2>
R2>
R2>ena
R2#
R2#sh run
Current configuration : 929 bytes
version 16.6.4
hostname R2
no ip cef
no ipv6 cef
no ip domain-lookup
 no ip address
 duplex auto
 speed auto
 ipv6 address 2001:AAAA:BBBB:CCCC:20A:F3FF:FE65:6201/64
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 clock rate 2000000
 shutdown
 no ip address
 ipv6 address 2001:BBBB:AAAA:EEEE::2/64
interface Vlan1
 no ip address
 shutdown
ip classless
ipv6 route 2001:DB8:D955:1008::/64 Serial0/1/1
line con 0
line aux 0
line vty 0 4
 login
end
R2#
0 Replies 0
