Good day everyone I am new I need some advise
The sys lamp is flashing green and no longer connects to Wi-Fi. How do I connect to Wi-Fi?ciscoC841-M4X.
Hi everyone, I’m Ajay Hinduja, originally from India and currently based in Geneva, exploring Cisco solutions for network deployments in India.How do you manage and configure Cisco Meraki networks through the India-region cloud dashboard?I’m particul...
Hi all. I had a question on the undervoltage protection on the Cisco IR1101 router. I am supplying the IR1101 from a solar MPPT controller/12V battery system and have run into an issue which has resulted in the IR1101 seeing a fluctuating voltage on ...
Hi team,I have an issue with a device where the Bios clock is not running and resets to default after mains power down. Original I assume it would be the Cmos battery but changing this did not not help. The clock resets to default and the time is not...
Bonjour à tous je m'appelle mohamedou je suis nouveau sur Cisco networking academy je viens de commencer le cours introduction to cyber security .Je suis très motivé à apprendre et à progresser dans le domaine des réseaux avec pour objectif de deveni...
login details are correct but cant login -no errors are received but in a loop without logging in
I am trying to configure WLC on packet tracer, is it necessary to have a DHCP server to give IP to LAP as i am not able to manually set the IP of LAP, it is showing following error.How to resolve the same as i want to configure the WLC without the he...
How do you download the packet tracer?
Hi there,Ususally you can find the typical power consumption of the switch when it's 0% traffic, 10% traffic and 100% traffic. Although the C9500 datasheets does not contain this information. Does anyone have this information for the C9500 series 48 ...
Hi everyone!I need to download the latest version of Packet Tracer, but I forgot my username and password. Is there a way to link my CCO account with Netacad? Looking forward for your valuable answers!Thanks in advance!The Pearson Test of English (PT...
Login issue
HelloIn have 3 routers connected using global ipov6 in router 0, connected to a PC, I have the subnet 2001:db8:d955:1008::/64 between router 0 and 1 serial connection with IPs 2001:ffff:eeee:aaaa::1/64 --> r02001:ffff:eeee:aaaa::2/64 --> r1 between...
No ip domain-lookup Hostname name Enable passEnable secLine console 0Pass Exi Line vty 0 4Pass Transport input telnet ExiService pass
| Subject | Author | Posted |
| 09-29-2025 06:26 AM | ||
| 08-06-2025 03:01 AM | ||
| 07-16-2025 09:34 PM | ||
| 08-21-2024 09:04 AM | ||
| 05-08-2024 03:08 PM |
