1:. What is the use of "RESET" button in cisco WS-C3750X-48P switch back panel?2:. What is the difference between "MODE" button in frontside and "RESET" button at backside of cisco WS-C3750X-48P switch.
Hi community, Could you please let me know where I can find the latest Cisco Start Catalog for 2025, similar to this one:https://www.cisco.com/c/dam/m/en_sg/cisco-start/assets/pdfs/cisco-start-catalog-connect.pdf Thank you in advance for your help.
Hi everyone, I’m Ajay Hinduja, originally from India and currently based in Geneva, exploring Cisco solutions for network deployments in India.How do you manage and configure Cisco Meraki networks through the India-region cloud dashboard?I’m particul...
Hi all. I had a question on the undervoltage protection on the Cisco IR1101 router. I am supplying the IR1101 from a solar MPPT controller/12V battery system and have run into an issue which has resulted in the IR1101 seeing a fluctuating voltage on ...
Hi team,I have an issue with a device where the Bios clock is not running and resets to default after mains power down. Original I assume it would be the Cmos battery but changing this did not not help. The clock resets to default and the time is not...
Hello Cisco Community,I'm reaching out here because my team has been experiencing significant difficulties trying to update our company's details within the Cisco portal. We've been attempting to contact the Business Partner Service for over two week...
I left job in feb'20 and wanted to remove my cisco ID associated with my last company. I tried to do the same under the profile page, but unable to do so. Currently, I'm not working with any company. I sent an email to cisco 2 weeks back also but di...
Bonjour à tous je m'appelle mohamedou je suis nouveau sur Cisco networking academy je viens de commencer le cours introduction to cyber security .Je suis très motivé à apprendre et à progresser dans le domaine des réseaux avec pour objectif de deveni...
I got a brandnew CBS350-48T-4G CISCO Switch.It should replace an HP ProCurve 3400 which runs out of ports (24).The CISCO should be configured:1-40 to local (192.168.100.n)41-44 to DMZ45-48 as trunk to another HP ProCurve switch.VLAN 1 is lokalVLAN 2 ...
