Example Workflows
Update: Along with the release of Workflows, Cisco has launched the Workflows Exchange. This ever-growing library of sample workflows allows you to easily find automations that meet your needs, and either run them as-is or use the simple drag-and-drop editor to tailor the workflow to match your specific needs. You can browse the Exchange, right within the Automation menu in the Meraki Dashboard and get started today.
Network Platform Team
Workflows - Technical Marketing Engineer
7 Replies 7
Blink Meraki Device LEDs
This is a custom Workflow created by enovak that requires a Meraki device Serial Number as input and will blink the device LEDs. This workflow uses a Generic Meraki API Request Action to the Create Device Live Tools Leds Blink API to enqueue a job to blink LEDs on a device.
It should be noted that when you use the Generic Meraki API activity in Workflows, you need to provide the full path, including /api/v1/
To import this example, you will need to change the file extension from .txt to .json
Check Available Firmware for Network
This workflow requires a Meraki Network Name and either a Meraki Organization ID or Meraki Organization Name as input. The workflow returns JSON objects for the current and available firmware versions for Appliance, Switch and Wireless devices on the Network.
Python Script Activity Example
This simple workflow is an example of a Execute Python Script Activity that shows how to map variables into and out of a Python Activity in Workflows. Check out the new demo video that describes this workflow.
It may be helpful to also review the Workflows documentation for Execute Python Script as well as the list of supported Python modules.
Here's a second example that shows both ways to map a Workflows variable into a Python Script activity.
Select and Schedule Firmware Update by Network Tag
Custom Workflow by enovak that takes a Network Tag as input and then pauses with a User Prompt to select firmware versions for Appliance, Switch, and Wireless devices and the date and time to for the firmware update. (User Prompts are found on the dashboard under Automation -> User Tasks -> Prompts) After the User Prompt has been submitted, the Workflow continues and loops through all networks that have the supplied Network Tag from all Organizations the selected Meraki Key has access to and schedules the firmware upgrades.
Nested Loop Example
This example workflow shows how to use nested loops to overcome the current workflows limitation of 500 iterations per loop.
Copy Meraki Switch Port Configurations
Custom workflow created by enovak that copies the switch port configuration from one Meraki switch to another.
If Copy All Ports is set to True, the workflow will copy the configuration from Source Switch Ports to Target Switch Ports for all Port IDs <= the Source Switch Port ID count. The Source Switch MUST have <= the ports on the Target Switch. If the Source Switch port count is > than the Target Switch port count, the workflow will stop and report an error.
If Copy All Ports is set to False, the workflow will copy the configuration of the provided Source Port ID to the provided Target Port ID. The Port IDs MUST not be 0 and must be valid numeric Port IDs on the selected devices.
NOTE: This workflow does not work for Port IDs that are not numeric., i.e. "1_MA-MOD-2X40G_1" or "1_MA-MOD-8X10G_8"
If Convert Allowed VLANs from all to 1-1000 is set to True, any port that is configured as a trunk with Allowed VLANs set to all will copy as Allowed VLANs set to 1-1000
🚀 New Cisco Workflows Learning Series Video + GitHub Automation Repo Now Live! 🚀
Hey Cisco Community!
We’re thrilled to announce the latest addition to our Cisco Workflows Learning Series: “Connecting Cisco Workflows with GitHub Repositories”! 🎬
What’s in the Video?
In this hands-on walkthrough, you’ll learn step-by-step how to set up GitHub Repositories right inside Cisco Workflows. We’ll cover:
• Downloading workflow content directly from GitHub
• Saving your workflow automations back to your repos
•Best practices for seamless integration and version control
Whether you’re a beginner or a seasoned workflow automator, this video will help you supercharge your automation journey!
👉 Watch the video
Introducing the Cisco Workflows Automation Git Repo!
To make things even easier, we’re launching a brand new Cisco Workflows Automation Git Repository packed with ready-to-use example workflows until the Workflows Exchange is ready. Clone or customize these workflows on your own—this repo is your playground for workflow innovation!
🔗 Check out the repo
