@giovanni.augusto You are correct that Workflows currently has Target Types defined for Azure AI and Open AI. I will pass your request on the the team for adding Gemini AI. The best method to submit enhancement requests is to use the 'Give your feedback' button on the bottom of the page in the Meraki Dashboard. All of the submissions there go directly to the Product Management team.
You could use a HTTP Endpoint and a Web Service HTTP Request Activity and create your own custom Atomic for Gemini AI using the Gemini REST API. To create a custom Atomic, your workflow must only contain Activities and Logic actions. You can select the 'Is atomic workflow' checkbox in the workflow General properties area and you can either assign an existing Category, or create a new Category like "Gemini AI" that your custom Atomic will be available in on the left hand Activities column.
