Vikram Hosakote
In the movie Ghostbusters, Zuul is the demigod and gatekeeper of Gozer, the destructor.
In OpenStack, ZUUL is a program used to gate the source code repository of a project so that changes are only merged if they pass tests.  Zuul is a pipeline-oriented project gating system that facilitates running tests and automated tasks in response to gerrit events.
Zuul - A Project Gating System — Zuul 2.5.2.dev44 documentation
Zuul — OpenStack Project Infrastructure 0.0.1.dev12032 documentation
GitHub - openstack-infra/zuul
Components of Zuul:
  • Connections (Gerrit, SMTP)
  • Triggers (Gerrit, Timer, Zuul)
  • Reporters (Gerrit, SMTP)
  • Zuul Cloner
  • Launchers (Gearman Jenkins Plugin)
  • Statsd reporting (Metrics)
  • Zuul Client
Zuul architecture:
Zulu-Jenkins Integration:
The Gearman Jenkins Plugin makes it easy to use Jenkins with Zuul by providing an interface between Jenkins and Gearman
(https://wiki.jenkins-ci.org/display/JENKINS/Gearman+Plugin).
Gearman Plugin passes Zuul Parameters as Jenkins build parameters (http://docs.openstack.org/infra/zuul/launchers.html#zuul-parameters).
Example Jenkins Git SCM plugin configuration:
Source Code Management:
    Git Repositories:
         Repository URL: <your Gerrit or Zuul repository URL>
        Advanced:
        Refspec: ${Zuul_REF}
        Branches to build:
        Branch Specifier: ${Zuul_COMMIT}
    Advanced:
        Clean after checkout: True
Zuul v3 supports multi-node.  Example multi-node playbook:
### openstack-infra/zuul-playbooks/zuul-multinode.yaml
   hosts: controller
   roles:
     - zuul-controller
   hosts: compute
   roles:
     - zuul-compute
To deploy Zuul on bare-metal, devstack-vm-gate-wrap.sh must be replaced with bare-metal orchestration.
devstack-vm-gate-wrap.sh - openstack-infra/devstack-gate - Run DevStack in the gate
OpenStack Kolla deploys OpenStack cloud in Docker containers in gate using Zuul.
Kolla - OpenStack
project-config/kolla.yaml at master · openstack-infra/project-config · GitHub
Other useful links needed to deploy Zuul:
Cisco Cloud Native resources:
