Umbrella Reporting api v2 redirects to another hostname
Nishith
While accessing Umbrella Reporting API(reports.api.umbrella.com), it is redirecting to another hostname(api.us.reports.umbrella.com) without passing the required bearer token in the header.
It is the behaviour of all HttpClients implementation.
Hence, while accessing the API, it is returning as "401 Unauthorised".
In Postman , if the option "Follow Authorisation Header" is selected, then we are getting successful response.
How do we acheive it through code. Tried the exact java sample available in Github. it is failing.
The API Guy
Hi there,
Please see the following guidance: https://developer.cisco.com/docs/cloud-security/#!reporting/http-redirects-and-request-authorization-header
In addition, please note that the above points to the new Umbrella API (reporting v2 will be EOL this September 2023). You can find guidance for the new reporting  endpoints by following this link. The reference to these endpoints can be found here
Yaron
