Blocked device still connecting
ebaierl
Community Member
I've got a user who is clearly torrenting and I want to block them. I changed their device policy from Normal to Blocked, but did not add a message, and it seemed they were blocked. But I check again today and they have managed to use a lot of data in only a couple hours by connecting to nearly a hundred IP addresses. This time I blocked them again and sent them a message, but I can't tell if it worked or not. It said they were blocked before, but still managing to get through somehow.
Is there something I missed or some other way to do this?
6 Replies 6
BBETTE
@ebaierl
If you're absolutely sure that you applied the block policy to the client, then it's probably best is to contact support.
Australia/Asia-Pacific +61 286078968
Europe +44 203 808 7003
North America +1 415-937-6671
Keep in mind that the block policy uses the MAC address, and some OSs, Windows 10 is one of these, already include a mac address generator, which can cause havoc for a network administrator.
ebaierl
Community Member
Well, it says blocked on the client page, and yet they are still connecting to and using bandwidth. I know they should be able to connect to the SSID, but they shouldn't be able to connect to the outside internet. I also tried setting up a group policy of banned uers and just blocking all traffic, and they were still getting through somehow.
I'll have to give support a call and see what I'm doing wrong.
ww^
Meraki Community All-Star
Additional you can try shape the torrent traffic to as low as possible
MerakiGnome
Where and how are you blocking the client?
Please correct me if I’m wrong but you can only block using an MX or MR. If you don’t have the above the dashboard allows you to block or whitelist the client but it’s not enforced.
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
I was going through the Clients link on the MR AP page. It wouldn't let me block them completely though, it said they were blocked, but they were still using bandwidth. I was able to reduce their bandwidth as much as possible (down to 20kbps), which I think annoyed them enough to stop doing it, but they were not blocked.
They have left the campground, so the issue is gone now, but I want to be able to have the option to do it in the future.
We do have an MX and three MR. I was going through the MR page though, didn't even think to go through the MX page, but I'll try that next time we have an issue.
mjvenema
Community Member
Also it's not very hard to spoof a MAC address even for a non technical user. I would recommend blocking the traffic type if you don't want to allow torrents at all.
