03-15-2025 01:30 AM
Solved! Go to Solution.
03-15-2025 06:31 AM
As @jdb1 said, if you go to the devices tab and select a device, you should be able to assign a license, you will see the 1 year MR licenses that you bought, change the quantity to 1 (from 0) and then hit next. Once complete the expired license will be unassigned and the new license will be assigned to the AP.
03-15-2025 02:00 AM
Thats just the 90 days activation window. You should be able to use them
03-15-2025 02:12 AM
03-15-2025 02:19 AM
03-15-2025 02:23 AM
How do i apply the unused licenses to the devices without without waiting till the activation date?
03-15-2025 02:31 AM
In the Per Device Licensing model you can only have one example of each license type applied to a device. When the existing licenses expire, the new licenses should automatically be used. You also will not suffer an outage whilst this happens.
03-15-2025 02:33 AM
Apologies, I've seen that the automatic replacement didn't work... In which case you need to unassign the current expired 4 year license from each device and you can then assign one of the new ones. They will backdate and start from the 10th.
03-15-2025 02:34 AM
As you have seen, the PDL model is a bit broken, hence why no new customers can migrate to it...
03-15-2025 02:45 AM
I ve tried to unassign the current expired 4 year license from each device but it is not highlighting on the dashboard.
03-15-2025 06:18 AM
Go to the devices . And assign the new license
03-15-2025 06:31 AM
03-15-2025 04:31 PM
Thanks a lot.
I was been able to assign the licenses.
You recommendation worked
