Custom Field for device
lbrown2
Community Member
is there a way to add a custom field in the MDM device details?
Thanks!
ConnorL1
Meraki Employee All-Star
It's included if you do a CSV report, or use the API to gather details. In terms of other reports, I don't know, unfortunately. What are you ultimately wanting to track/report on?
6 Replies 6
BlakeRichardson
Meraki Community All-Star
Not that I have seen sorry. What are you trying to achieve, is it something that you could use TAGS for?
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Unfortunately no, but thank you for the suggestion!
ConnorL1
In short, no - this would be a feature request. However, you could use the "notes" section to achieve this though.
lbrown2
Community Member
Thanks, We were considering using that. do you know if a report can be generated based on the notes field?
ConnorL1
lbrown2
Community Member
Thanks!
We want to track a purchase date.
