Dark-Mode is there
MK231
Level 6
Level 6
I don't know if I was dreaming, but suddenly it was there... Dark Mode 🙂
Thank you, Meraki.
jvaldez2
While preparing to make dark mode available, we unintentionally exposed it via the new feature highlight popover before it was ready. While that provided a way to opt-in to the dark mode preference, the selector to change the setting back to light or system default mode was not also available.
We're excited to make this available in the coming weeks when it's ready, and you'll be able to try it out and choose the theme setting that works best for you.
19 Replies 19
BlakeRichardson
Meraki Community All-Star
I just noticed that as well, great to have new features but I would really like the new version of the dashboard to be reliable.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Its unusable on mobile. I have not even bothered to figure out why claiming SNs doesnt work.
heathicus
Frequent Visitor
Frequent Visitor
Yeah, but it looks so weird, and I can't find a way to turn it off. Usually I'm a dark mode junkie, but it looks like that "high contrast" windows mode and then I can't find anything. Anyone found a way to turn it off?
I opened a case to ask about it yesterday. This morning, they said, "due to issues with legibility the option to switch to and from dark mode has been disabled." Following that they said to delete cookies.
But this morning it looks to have reverted to light mode, so did they retract the update? Fix my profile? No idea. Haha.
ezuniga
Community Member
How do I disable it though? It's not working well with my browser, I can't read a lot of the text.
CMR
Just go to Profile -> Theme
Oh wait, there is no Profile -> Theme...
Hopefully we don't need to wait a few more years for the GUI setting to show up!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
Make a wish to enable a toggle function 😎
Ryan_Miles
Meraki Employee All-Star
Eng is aware and working on fix for lack of theme toggle
Kelove
Community Member
I enable dark mpde and now i cannot revert it back to its original
is their a way to disable the dark mode?
SuperM
Community Member
Same issue, hopefully they fix it soon as I am not really liking dark mode unfortunately.
VRB1
Level 2
Level 2
Same here, waiting for the toggle switch. They forgot to put it. haha
Adam Hinchliff
Level 4
Level 4
I thought I wanted it but its horrible haha. Instant regret saying yes.
Adam Hinchliff
Level 4
Level 4
Work around - Enable desert high contrast theme in Win11
MK231
Level 6
Level 6
Why did I press that button?😭
I thought I would be happy, but now I'm frustrated.
