Dashboard issue after removing hardware
BlakeRichardson
Meraki Community All-Star
So last week I replaced a switch that was faulty. Yesterday I removed said switch from the network it was part of and now whenever I search for anything using the Network-wide > Clients page I get an error in the "connected to" column
It looks like every single client is showing this error even though I know for a fact the majority were not connected to this switch directly.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Philip D'Ath
What have you got "Client Tracking" set to?
If it is set to "Unique client identifier", try changing it to "MAC Address", save (which will delete the client tracking database), then change it back.
BlakeRichardson
The network does not have an MX it's already using MAC
Philip D'Ath
Will it let you change to IP and then back to Mac?
