Dashboard Issue with Adding, Removing and moving devices between networks
prativya
Meraki is aware of the issue with adding, removing, and moving devices between networks. It is being worked on with the highest priority, more updates will be provided here as they become available.
Apologies for the inconvenience.
Meraki Team
prativya
Thank you for your patience while we were working on this. A fix has been deployed and we can see devices can be added, removed, and moved successfully between the networks within Meraki Dashboard. Please give it few hours if it doesn't work initially as it can take some time for the fix to roll out across all our cloud servers. If the issue persists after few hours, please reach out to Meraki Support.
Meraki Team
prativya
Thank you for your patience while we are working on this. Our Engineering team has identified the cause and is actively working on mitigation.
Meraki Team
prativya
Meraki Team
