Dashboard Performance Issues – Device Data Loading Delays
Shubh3738
Level 6
Level 6
We’ve observed that over the past few days, the Meraki Dashboard has been experiencing occasional delays when loading device data.
At times, the dashboard fails to load device details altogether or throws an error during loading.
Is this a known issue currently being investigated? Any updates or recommendations would be appreciated.
JamesJP
Hi @ershubhsingh373
Would you say, you've noticed this occurring on a specific device type (e.g. MX,MS) or on specific tabs on a device, such as Device Health or Location?
Also worth checking if accessing the dashboard from a different LAN yields the same results
If you found this post helpful, please give it Kudos. If my answer solves your problem please click Accept as Solution so others can benefit from it.
I’ve noticed some inconsistencies with the overall performance of the Meraki Dashboard.
Here's the examples.
guitbbb
Level 2
Level 2
I'm facing the same issues here, dashboard is taking too long to load.
