Difference between Client usage and Client detailed usage
roOl
Community Member
I've difference on client usage and detailed client usage.
Can you help me understand those values ?
roOl
Community Member
Hey,
meraki support tell me the issue is now fixed.
7 Replies 7
aleabrahao
Meraki Community All-Star
Client usage is the sum of Download and Upload, Client detailed usage separates the two.
You can add that you will see that it makes sense.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
Or you probably applied some filter wrong.
roOl
Community Member
Hey alemabrahao,
total value is around 33Go when in the detailed view, value is 1.6To
Am I missing something ?
ww^
Does the detailed view value change if you set the range to 2 hour?
I think that 1.6Tb is from the 2 days active time. Not from 24h
roOl
Community Member
Hey WW,
yes, value changes when I change the range ( device is currently unplugged, so I dont have value on the last 2 hours)
yet, if I follow your logic, for this device in 39 days I have a 29To usage, when usage shown for 30 days is only 620Go. I dont think adding those 9 days would close the gap.
roOl
Community Member
Hey,
mrhammer
Community Member
up
