ECMS practice question - May 14th
SandroNa
Another week has gone by and as usual brought a weekend and an ECMS practice question!
Comment below with what you think is the correct answer and remember: if you like the question or the ECMS questions initiative, leave a kudo.
See you in a week with the correct answer!
Which statement correctly describes the minimum Dashboard configuration requirements in order to turn on the wireless connectivity option for MV Cameras?
  1. A minimum of 1 wireless profile need to be defined and assigned as Primary
  2. A minimum of 2 wireless profiles needs to be defined and assigned, one as Primary and the other as Backup
  3. A minimum of 2 wireless profiles needs to be defined and assigned, one as Primary and the other as Secondary
  4. A minimum of 2 wireless profiles needs to be defined and assigned, one as Primary and the other as Secondary and Backup
P.S. We will be sharing new practice questions weekly! If you'd like to receive updates when we do, click the "ECMS Practice" label below and then "Subscribe”
Here you can find previous questions
~~If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it.~~
The Meraki ECMS exam is now live! Test your knowledge of Meraki and become an official Cisco Meraki Solutions Specialist. More info on the ECMS exam found here.
For information regarding all of Meraki's training offerings, be sure to check out the Meraki Learning Hub.
17 Replies 17
@Karsten Iwenthat would be icing on the Meraki Lime Cake yes 🙂
Greetings @andburne please can I know how many questions are in the cisco meraki CMSS 500-220 ECMS Exam?
We are not allowed to share that officially. Its a manageable number.
