Firmware Upgrades
Joshua T
Community Member
Is there a way to all appliances in our stack to auto-upgrade the firmware?
aleabrahao
Meraki Community All-Star
You can schedule it:
https://documentation.meraki.com/General_Administration/Firmware_Upgrades/Managing_Firmware_Upgrades
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
CMR
@Joshua T if you mean apply updates without having to schedule it, then the only option to get more frequent updates is to tick the try beta firmware in Network-wide Configure / General as below, otherwise you should get updates a few times a year:
If my answer solves your problem please click Accept as Solution so others can benefit from it.
Joshua T
Community Member
Thank you, to everyone who suggested a fix.
Kave
Community Member
HTTPS Issue has ben solved on L3 Switch and MX -firmware issu on 17 x Ver or higher
We are using MX105 and MS 250.
had issue with firmware upgrade when upgrade from 16 x to 17 x or higher ver.
problem was HTTPS traffic got slow even with good bandwidth .
Please use Unique Client Identifier instead MAC addres as shown on screen shot.
you can find it in Security & SD-WAN --> Addressing&VLANs
kav noroozi
