Help Center
How do I get this "Help Center" to disappear? It appears directly over the "Give Feedback" button. It's not on every page, but on the Client-VPN page, for example.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
MerakiGnome
Meraki Community All-Star
Click on it and type “Go Away”
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
6 Replies 6
aleabrahao
I think it's not possible, but maybe you can ask the Meraki support.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
MerakiGnome
Darren OConnor
I already shouted it; do I really have to type it?
EDIT:
I can't believe it. That worked. After typing it changed the form and left a row of approximately one pixel to click on:
MerakiGnome
Darren OConnor
Ryan_Miles
Meraki Employee All-Star
I use a browser plugin called click to remove element and zapped it that way
BlakeRichardson
@Karsten Iwen So you didn't ask the help button for help on making it go away? 😂
