Management-interfaces and Programmatic interfaces for Cisco Catalyst Devices
timothyc95
Frequent Visitor
Frequent Visitor
What is the purpose of each management and programmatic interface for configuring, monitoring, and maintaining Catalyst deployments?
Management-interfaces:
  • CLI
  • WebUI
  • Cisco Catalyst Center(or DNA Center)
Programmatic interfaces:
  • NETCONF
  • RESTCONF
  • gNMI
aleabrahao
Meraki Community All-Star
Thanks for the great answer with links.
kathleen
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it.
mloraditch
You may also want to take your further questions to the regular Cisco Community: https://community.cisco.com/
This community is focused on Meraki and while many of us have cross pollinated over the years, more folks over there will be up-to-date and able to answer.
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
kjettlun
Since this is a Meraki page I have provided a couple of links to the Meraki/Catalyst KBs. Hope this helps.
Cloud Monitoring for Catalyst Wireless FAQ - Meraki
Link to Meraki Catalyst KB's
Kathleen
