Meraki Test Lab?
gfrazier
Level 3
Level 3
I was wondering if there is any sort of Meraki online testing lab to where you can setup and test a network design before purchasing and putting the devices into production.
BlakeRichardson
Meraki Community All-Star
@gfrazier Meraki offer try before you buy, they will send you brand new hardware, if you like it can can simply purchase the equipment, if not you can return it.
https://meraki.cisco.com/free-demo/
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
I was hoping that since it is cloud-managed, there would be some way to setup the configs on a virtual setup.
BlakeRichardson
Not that I have seen however reach out to your sales rep as you never know.
Generally testing means connecting something to it - preferably your 'thing', used by your people, accessing your apps in your way. Free trials are definitely the best 😁
If you just want to see something configured, you may be able to go through your Meraki account team, to get a demo - it depends how involved that is. You may be able to get something similar from your preferred Cisco partner, too.
