MV72 dome replacement
Jaguar2026
Community Member
Can we purchase a dome replacement for an MV72 camera?
ahbhatty
For MV22, its MA-MNT-MV-62
For MV72, its MA-MNT-MV-63
5 Replies 5
ahbhatty
CMR
Meraki Community All-Star
@ahbhatty those are mounting kits, are you sure they include a replacement dome for the camera?
If my answer solves your problem please click Accept as Solution so others can benefit from it.
CMR
Apologies @ahbhatty I see that indeed it does! Excellent 😎
What’s included:
  • 1x mount plate
  • 1x optical dome
  • 1x desiccant
  • 1x waterproof gland
  • 1x cable outlet cover
  • 1x conduit adapter
Is MA-MNT-MV-63 also suitable for MV72X? just want to check before ordering.
Is anyone able to confirm that the dome in the MA-MNT-MV-63 fits an MV72X ??
