MX Firmware Upgrade
sean.pickering
Community Member
I have a bunch of MX devices currently on MX 17.10.4 that I'm looking to upgrade.
I only ever use stable release but I can see there is MX 17.10.9 and MX 18.107.2 available.
When I select the target firmware 17.10.9 is the latest patch and 18.107.2 is the latest stable which i can go to.
I'm not sure as to which version to go to, is version 17 now at the end of its life and should I look to go to 18?
If anyone could help advise that would be great.
Many Thanks
aleabrahao
Meraki Community All-Star
I suggest you test version 18.x in a smaller office to validate if it will be stable and, once validated, update the other offices.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
jfigueroa1
Community Member
Hello, s34np
Meraki runs automatic schedule firmware upgrades. We went from the 17.X to MX 18.107.2.
FIRMWARE
Up to date
Current version: MX 18.107.2
This current version is of MX 18.107.2 is very stable i recommended.
A. Not longer see alerts on AP stating DNS misconfiguration.
BlakeRichardson
I am running version 18 on my networks however as mentioned you are best to test that it's stable for your setup and not rely on others findings.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
