Setup 2 wan interface but when using Flow References no internet traffic coming out on wan2
GelC
Community Member
I have a concern regarding mx100. we have 2 wan interface. my primary link is wan1. Both wan1 and wan2 are working and tested then each link have different isp provider.
Now here's my concern, I was told that if i want to send a certian ip or subnet to have internet traffic go out to wan2 i just need to set it up on the Flow References -> Internet Traffic. So I did, but unfortunately the internet traffic still goes out to wan1 even if when I check public ip and speedtest.net its showing the wan2 details. The Internet traffic only go out to wan2 when i change the primary link to wan2.
Philip D'Ath
Meraki Community All-Star
The preferred uplink only takes affect for new flows. When you change it you need to make sure the MX has gotten the new config first, and then quit the browser and open it again it make sure it is a new flow. Even then it might still use a cached flow for the next 10 minutes or so.
32 Replies 32
aleabrahao
If you are testing with ICMP it's normal, check the note:
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
GelC
Community Member
Hi Alemabrahao. Im not testing icmp. I'm actually sending a certain ip/subnet using Flow References -> Internet Traffic to wan2. Then after saving my changes still my internet traffic goes outside wan1 even if i do a speedtest the internet speed reflect on wan1.
aleabrahao
I'm confused, because you sad "even if when I check public ip and speedtest.net its showing the wan2 details"
aleabrahao
On speed test which IP is shown to you from wan1 or wan 2? Check It:
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferences#Load_Balancing
GelC
Community Member
My load balancing is disable. I dont need the traffic to be spread across both uplink.
GelC
Community Member
Oh sorry for the confusion. So if i use Flow References -> Internet Traffic then sent a certain ip/subnet on wan2 then check using whatsmyip and do a speedtest it will show my wan2 public ip but the internet speed still reflect on wan1.
aleabrahao
Speed test is based on ICMP 🙂
GelC
Community Member
So how do i know or how do i check if my my changes on Flow References -> Internet Traffic is successful if speedtest, traceroute, packet capture is still showing my wan1 ?
aleabrahao
If the speed test is showing the WAN2 IP It's ok, all those tests are based on ICMP.
GelC
Community Member
I think its not ok if I'll tell a client that i already sent his ip to wan2 but the result is still showing of a wan1 speed result.
aleabrahao
So, you should open a case with Meraki team support to check It. 🙂
GelC
Community Member
yeah i think i'll do this if i still cant figure this out. thank you Alemabrahao
aleabrahao
@GelC , Did you open a similar case 6 hours ago?
Raphael_L
No.....
It's TCP based
