White papers
Ulusha
Community Member
Can you use/share the Cisco Meraki White papers on your own company website?
Why not share a link with your own "teaser". That way you will reference always the most recent version.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Philip D'Ath
Meraki Community All-Star
On the whole - I wouldn't do it. I would run with @Karsten Iwen suggestion and just link to it.
You would need to be very careful. First, you'd need to be a Cisco partner or have some kind of existing legal relationship that would allow you to publish Cisco logos and trademarks (which all Cisco whitepapers or guides will have on them).
There are the initial logo rules:
https://www.cisco.com/c/en/us/about/brand-center/logo-usage-guidelines.html
Cisco's logo can not feature more prominently than yours or any of your branding. You can not give the impression that Cisco is endorsing your company.
Then depending on your Cisco partnership, you need to go check the rules for your level and see what it will allow you to do.
Thank you very much this was very helpful.
