WiFi 7 Plans
MerryAki
Level 5
Level 5
Hey there, are there plans to leverage WiFi 7 for Meraki? (Affordable mGig switching+APs?)
I mean, most sites still use WiFi 5/6 (some might be lucky and went for 6E)
Today there was an announcement at UI:
ui.social/u7pro
Thrilled to see more!
Yes, that's the Meraki forum, but I will definitely test it.
16 Replies 16
BlakeRichardson
Meraki Community All-Star
Meraki doesn't publicly share it's development road map. Cisco is not trying to compete with all vendors, any company that does would go out of business. At the end of the day you should be picking a product that's right for you.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Paccers
Level 5
Level 5
I'd avoid buying in to the the Wi-Fi 7 marketing machines for a while, the 802.11be standard isn't even ratified yet for starters!
