Can't obtain authentication token from Nexus 9000 Switch with Postman
oslopez
Hello everyone,
I'm learning to use the NX-API REST via Postman. Currently I'm in the process of obtaining an authentication token from the NX9k switch following the below steps:
Capture.JPG  Since the switch I'm reaching uses TACACS as a method of authentication I assign "name" and "pwd" with my Tacacs credentials.
However, once I hit the SEND button I get the following error:
(The actual Switch IP address is 10.18.1.2)
I tried the same steps in another switch with uses no TACACS but the default admin/admin credentials, however I got the same error.
Could you advise on why the connection is getting refused?
As mentioned, the Switch uses TACACS for authentication and the feature nxapi has been added.
Thank you.
Well, I just wrote a Python script and I was able to login without any issue, so I would say this is a Postman issue. My goal is to eventually write Python scripts to manage/configure Cisco gear, therefore I will ditch Postman and will focus on Python scripting.
Thank you.
6 Replies 6
Sergiu.Daniluk
HI @oslopez
You are talking about NXAPI, however you are using ACI API login.
If you have your N9K switch running in NXOS mode, have a look here: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/programmability/guide/b_Cisco_Nexus_9000_Series_NX-OS_Programmability_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Programmability_Guide_chapter_011.html
If you have an ACI fabric, use the APIC IP to login.
Stay safe,
Sergiu
Hi msdaniluk,
In fact, what I'm following is a lab at Ciscolive :
http://opennxos.ciscolive.com/pod0/labs/lab3/lab3-m2
Already completed previous modules but currently I'm stuck at Module 2: Postman - NX-API REST with the error mentioned.
As far as I'm concerned, this lab is based on a N9K switch, not an ACI fabric, That's why I'm using a N9K switch. Already was able to access the Sandbox, but I'd like to get more proficient using Postman, that's why I'm trying to go through the authentication process.
Thanks for your help.
So it seems NXAPI REST is using same DME logic to access MO objects as in ACI. And curious enough is still called APIC Cookie ^_^.
Try this:
  "aaaUser" : {
    "attributes" : {
      "name" : "apic:TacacsDomain\\username",
      "pwd" : "password"
NOTE: I haven't tested it as I do not have a tacacs in the lab.
Stay safe,
Sergiu
I don't have the Tacacs domain but I used the actual IP address of the Tacacs server along with my Tacacs UN and PW
"name" : "apic:<ip address of Tacacs server>\\username
But unfortunately I'm still getting the same error
Thank you.
I have the same issue, but I noticed that if you pass your creds in .xml request instead of json, it works, and you will receive your token back. You may notice that some tutorials show that json is working, but when you r trying same thing, json won't work. My assumption is that when the version NXOS changes, the organization of the authentication tree on the device may be changed too, so it is no longer matching the body that you trying to pass; i.e. it is no longer
    "aaaUser":{
        "attributes":{
            "name":{{username}},
            "pwd":{{password}}
The way I made it work on my side, I sshed into my nexus os device, did a show version, checked what is the NXOS version (in my example it was NXOS: version 10.3(3) [Feature Release] ), then I went to this link that I found on Reddit: https://developer.cisco.com/site/cisco-nexus-nx-api-references/ , and here I looked for the documentation for my version 10.3, and found the authentication section. The authentication section has recommended to use xml:
Then I simply changed my postman request to the following:
Now it is working.
