DEVNET - Hands On Exercise: Using Postman to Interact with REST APIs
m.howsmon
I'm trying to complete the lab in the title. One section has you export the code in python. I can't get the code to run because it is dependent on a "requests" library. Where do you get this library? I attempted to download it:
$ git clone https://github.com/CiscoDevNet/requests
Cloning into 'requests'...
remote: Repository not found.
fatal: repository 'https://github.com/CiscoDevNet/requests/' not found
If anyone know where I can get it I would appreciate it.
omz
Requests library is available on pip.
You can do -
pip install requests
to install the requests library.
If you are using virtual environment, don't forget to activate it before installing ... if you did something like .. source /bin/activate
If you didn't .. then you can ignore the activate part.
