DevNet - Learning Labs - issues with the fortune cookie =-) - '->' in Python syntax error
_|brt.drml|_
I'm going through the Devnet learning track and I have an issue with the interpreter )> Apparently they would not recognize the '->'
When I run it - it hangs there with a syntax error.
I understand a syntax error, but it won't go away.
Any thoughts how to solve?
Tested this with windows cmd python, in git bash ...
#!/usr/bin/env python
# -*- coding: utf-8 -*-
"""Script flow and debugging. Print your own fortune cookie!"""
import random
FORTUNES = [
" There is always good weather some day ",
" One day you will have a happy day ",
" Your kids would listen if you ask them something",
def generate_fortune() -> str:
return random.choice(FORTUNES)
def generate_lucky_numbers(how_many: int) -> list:
lucky_numbers = []
for _ in range(how_many:):
lucky_number..............................
6 Replies 6
omz
Can you share the error you are getting?
Check the version of Python you are using.
The code works in Python3.
Hi there,
The reply I get is:
$ py ./intro-python/part2/fortune_cookie.py
File "./intro-python/part2/fortune_cookie.py", line 16
SyntaxError: invalid syntax
I ran this code within the windows command and yesterday this worked.
Today it does not. :) Weird and as a beginner I do not see the issue.
All information points that it is 'valid'..
Btw - tested this in python 2 & 3
Check your syntax you might have added or deleted something .. on line 13 .. do still have the closing bracket " ] " for the list?
Does your line 9 - 18 look like this ..
FORTUNES = [
    "There is a good chance your code will work, eventually.",
    "The weather will be hot, cold or just right today.",
    "I see Network DevOps in your future.",
def generate_fortune() -> str: """Use mystical forces (a random selection) to get a user's fortune.""" return random.choice(FORTUNES)
I can reproduce the same error if I remove the closing bracket
python3 fortune_cookie.py
  File "fortune_cookie.py", line 16
Hi There thank you for the quick reply,
I did try moving that bracket, but no success. Weird... I moved it up, to the left, indented it...
So no changes so far.
Weird, as I made already other code but always without the '->' ..
FORTUNES = [
