No module named pip
armstrong4u2
Hello Team,
I am working Learning Labs for DevNet. ("Setting up your macOS workstation as a development environment"), and I need some help with setting up the Python2.7 virtualenv.
Setting up my Development Environment on macbook pro running macOS Mojave.
I have followed the steps but receiving some form of error message for this step "Install the virtualenv package for Python within Python 2."
Terminal Command:
  python2.7 -m pip install virtualenv
output message:
/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python: No module named pip
Kindly assist.
Thanks.
Try with
sudo easy_install pip
You need to enter your Mac OS X user's password.
Once pip is installed, try again
sudo python2.7 -m pip install virtualenv
LanDownUnda
Hi armstrong4u2,
Python if your not aware is extremely modular in the sense where when you first install python you'll have some modules automatically installed like "requests" for example. Package managers like PIP and other modules won't be installed by default so you'll need to install pip manually in order to then install packages using pip (catch my drift?).
An easy way of doing this is to do the following:
1. Download pip using the following command:
curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
2. Install pip using the following command:
python get-pip.py
I hope this helps!
*** Rate All Helpful Responses ***
lovelmark
Pip is a python packaging module that helps us too install python libraries. To install python libraries/modules ,you need to install pip-
sudo apt-get install python-setuptools
sudo apt-get update
which pip //to check pip install or not
pip install requests
Upgrade pip
python -m pip install --upgrade pip
for Python 3:
python3 -m pip install --upgrade pip
for Python 2:
python2 -m pip install --upgrade pip
