Problem displaying posts
Jon Marshall
Dan / Tim
Seem to be having a problem that has cropped up yesterday and today.
I have just posted a response into the thread about ratings in this forum and the respnse has had to start a 2nd page. Trouble is i can't see that response on the 2nd page, i just get a blank page.
Yesterday i was involved in a thread with Mike -
STP thread
in this thread also i posted a response that had to go at the start of the 2nd page. Mike then responded. I can see Mike's response on the 2nd page but i still can't see my one.
On a more general note, the display of the 2nd page over the last week has changed for me. When i go onto it the first half of the page is just blank and then i can view the responses.
Any ideas ?
Jon
19 Replies 19
Hi Jon,
Nope, that view is open for all to use.  Our IT is working on getting the flat view fixed and will let you all know when it's fixed.
Cheers,
Dan
Cheers, Dan
Dan
Thanks for this. Think i'll rate you for your extremely helpful responses
Jon
Dan
Quick update. Might be more than just Ubuntu. Just been involved in a thread with a poster who uses IE8 and they are unable to view my posts so it may not just be Firefox. I've pointed them to the threaded view.
Jon
hi jon, hello
first i read some fo your replies of the netpro community and i found them very helpful, so thanks for your contributions...
would you mind asking you a question about load balancing please,
i have two sites, site A & B, i'm the administrator of site A.
because the low upload speed that is allowed in the dsl connections
in this area i had to subscribe for another dsl connection to maximize
the speed of the upload. the only traffic that will be transmitted
between the two sites is a video conference traffic, so i have to
use the two dsl links to transfer the video conference traffic between
the two sites to be faster, therefor i installed a cisco 2811 router that has two ethernet
interfaces f0/0 and f0/1, each one connected to one of the dsl modems
via an ethernet cable . and then to configure a load balancing on the
two ethernet interfaces to distribute the video traffic over the
dsl links,
some people say that the video traffic will not be allowed to be
transfered over the two dsl links by load balancing.
so my question is, does the load balancing configuration on cisco
2811 router will let me transfer the video conference traffic over
the two links successfully with a fast and acceptable performance?
and in this situation it will be better to use load balancing per
destination or load balancing per packet ?
i appretiate your urgent reply
many thanks
makar
Hello Jon,
I have the same problem with firefox 3.6.3 and Windowss XP SP3 I cannot see some posts in second page not only if they are mine.
There is also another point for me: before moving to firefox 3..6.3 unified login worked well now it is nor working anymore and this is causing me a lot of issues I need to use two browsers one to navigate in forums and another one IE or google chrome
If I login in another tab again with cisco.com then the supportforums tells me that the site is not available. first time this happened I've waited some hours.
Hope to help
Giuseppe
