Ansible Error when running yml for ASA
Steven Williams
Level 4
Level 4
Keep getting an error when trying to configure a line on ASA:
root@bnaplxjmpnet:/etc/ansible# ansible-playbook asa03.yml
PLAY [show Anyconnect VPN connections for ASA] *********************************************************************
TASK [Set terminal page to zero] ***********************************************************************************
fatal: [10.53.0.105]: FAILED! => changed=false
  ansible_facts:
    discovered_interpreter_python: /usr/bin/python
  msg: operation requires privilege escalation
PLAY RECAP *********************************************************************************************************
10.53.0.105                : ok=0    changed=0    unreachable=0    failed=1    skipped=0    rescued=0    ignored=0
- name: show Anyconnect VPN connections for ASA
  hosts: CAO_ASA
  gather_facts: no
  connection: network_cli
  become_method: enable
  become: yes
  vars:
          ansible_connection: network_cli
          ansible_user: AnsibleReadOnlyUser
          ansible_ssh_pass: 12345
          ansible_become_pass: 12345
          ansible_network_os: asa
          ansible_become: yes
          ansible_become_method: enable
  tasks:
          - name: Set terminal page to zero
            asa_config:
                    lines:
                          - terminal pager 0
                    match: line
                    authorize: yes
                    username: AnsibleReadOnlyUser
                    password: 12345
          - name: Show version
            asa_command:
                   commands:
                           - show vpn-sessiondb anyconnect
            register: print_output
       # - debug: var=print_output.stdout_lines
          - name: copy output to file
            copy: content="{{print_output.stdout[0]}}" dest=./test-asa-results.txt
0 Replies 0
