Bypass pyats bringing device to "config" state
JanKrupa45054
I would like to use pyAts as a tool to read configuration from devices. I do not need to enter `config state` mode and I don't even have the rights to do that.
When I run my example code
from genie.testbed import load
from pprint import pprint
tb = load('testbed.yaml')
dev = tb.devices['R115']
dev.connect()
I end up with the error:
config term
% Invalid input detected at '^' marker.
unicon.core.errors.TimeoutError: timeout occurred:
              timeout value: 10
              last_command: 'config term\r'
             pattern: ['^(.*)\\(.*(con|cfg|ipsec-profile|ca-trustpoint|gkm-local-server)\\S*\\)#\\s?$', '^.*--\\s?[Mm]ore\\s?--.*$']
             buffer:"config term\r\nconfig term\r\n   ^\r\n% Invalid input detected at '^' marker.\r\n\r\nR115#"
unicon.core.errors.SubCommandFailure: (StateMachineError('Failed while bringing device to "config" state'), "config term\r\nconfig term\r\n   ^\r\n% Invalid input detected at '^' marker.\r\n\r\nR115#")
When the connect() command is executed, the following commands are executed
config term
device(config)#no logging console
device(config)#line console
device(config)#exec-timeout 0
device(config)#terminal width 511
device(config)#end
device#
Is there any way, to bypass these commands? (entering config state mode)
Thank you.
JanKrupa45054
Thanks to Antoine Orsoni
The connection below solves the problem
device.connect(init_exec_commands=[],
               init_config_commands=[],
               log_stdout=False)
@JanKrupa45054 if you do not get the reply here, head over to the pyATS Webex room here --> https://eurl.io/#r18UzrQVr
You can email our external customer mailer at pyats-support-ext@cisco.com. The development team is in EST time zone,
and will usually respond within a day - we will provide best-effort support for your question.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
JanKrupa45054
               log_stdout=False)
