how do I upgrade C9300 switch stack IOS using DNAC
pdmarshall
Frequent Visitor
Frequent Visitor
I have numerous switch stacks which I need to upgrade to cat9k_iosxe.16.12.04.SPA.bin.  'set as golden' in DNA software.
Within DNA I am using the following process
Switches-Software Images-Update images
I can upload the ios on the the stack, do a dir flash: and I can see it.
But it doesn't unpack it and load it and I get the following error message.
NCSW10024: The device is not managed completel
I can, using the same process do single switches and they follow the process fine.
And I can also log onto the stack after I have loaded the image using DNA and do the following command
#request platform software package install switch all file flash:cat9k_iosxe.16.12.04.SPA.bin
And it will unpack and load the ios.
I am just wanting to automate/schedule this process using DNA
I've tried looking through cisco docs but I just can't see what I am missing.
Anyone else had this issue and know a solution.
Many thanks
Phil
Alexander Stevenson
Hi @pdmarshall,
          I recently read a great Cisco Blog post about using Ansible with DNAC titled Ansible: Powered by Cisco DNA Center. It might help get you where you need to go.
Hope this helps!
