how to obtain interface input / output values
At times I need to check my 9300 Edge switches for unused interfaces so that i can either disable them or re-purpose them when they go under utilized.  typically i would check the input and out values and typically look for interfaces that have a output of "never".
after using the interface rest api call from DNAC or directly against a switch, this type of data does not seem to be present.  is there a way to obtain dynamically via a REST API call?
@OaklandCounty_Mike you could use tools like Netmiko, Napalm, Scrapli over SSH/Netconf. PyATS is a very popular choice too https://developer.cisco.com/pyats/ You can also do this with YANG, see https://developer.cisco.com/yangsuite/ to get started here.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
Thank you for your reply, I was hoping to not have to do it via a SSH connection. Maybe we will get rest api soon to provide this info.
Have a good day!
