pyats installation in virtual environment
yingying.yang
Community Member
I received the following message when I install pyats in virtual environment.
pip3 install pyats[full]
install pyats.PNGThen I received the following message when I try to use pyatsrun pyats.PNG
anyone has ideas about it? Thank you.
Good news, someone from the webex space guide me to pyats pubhub, the magic is
$ pip install --upgrade pip setuptools
 everything is good after upgrade pip with the latest setup tool package. Thank you so much for your help.
5 Replies 5
@yingying.yang it looks there is a clash in the version in Markupsafe. You can either uninstall/downgrade Markupsafe or start a new venv and install this from fresh. Hope this helps.
(new_venv)root$ pip install pyats[full]
Requirement already satisfied: pyats[full] in ./new_venv/lib/python3.8/site-packages (20.10)
[removed]
(new_venv) root$ pip list | grep pyats
pyats                        20.10
(new_venv) root$ pip list | grep Markup
MarkupSafe                   1.1.1
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hi bigevilbeard, thank you very much for your reply. still the same, I received errors when install pyats. It said "Building wheels for collected packages: yamllint, aiohttp-swagger, async-lru, tftpy, pyftpdlib, backports.ssl" error.
@yingying.yang hmm this is odd - i would join this support team space for pyats https://eurl.io/#r18UzrQVr and the team who run this project help support issues such as yours.
Hope this helps.
Thank you bigevilbeard, I just post the screenshot to the team space, hope can get a solution from it. I used pyats before, had no issue, not sure what affect it when I install it in new virtual environment.
