if it possible that N9K link a ODL as Controller?
uncleshuai
it if possible to connecting Virtual-N9K(NX-OSv 9000) to Opendaylight Controller (Beryllium-SR4-based)? and how, thx a lot.
giheron
sure - but what protocols are you looking to use?
AFAIK NX-OSv 9000 supports NETCONF/YANG and BGP.  Both of those are relatively easy to set up - I have some blog posts on here I think re setting them up using IOS XR.
I believe the Nexus 9000 also supports LISP and OpenFlow, but am not sure if those are supported on the NX-OSv 9000.
