ODL Boron and usage of initial configfile xml
thuydang.de
I'm having this error:
Caused by: org.opendaylight.controller.config.api.ValidationException: {isco-controller-main-impl={mycontroller-main-impl=Found module factory does not expose expected service interface. Module name is binding-data-compatible-broker : org.opendaylight.controller.config.yang.md.sal.binding.impl.ForwardedCompatibleDataBrokerImplModuleFactory@47591206, expected service interface interface org.opendaylight.controller.config.yang.md.sal.binding.DataBrokerServiceInterface, dependent module ON org.opendaylight.controller:instanceName=inmemory-binding-data-broker,type=Module,moduleFactoryName=binding-data-compatible-broker , attribute JmxAttribute{'DataBroker'}}}
at org.opendaylight.controller.config.api.ValidationException.createFromCollectedValidationExceptions(ValidationException.java:61)
Can anyone confirm that Boron version does not support initial configfile anymore? If not, is there any up-to-date tutorial/documentation about injecting config subsystem services using initial config?
Thanks!
eckelcu
Can you provide some additional context as to what is happening when this error is encountered? For example, is this when first starting a clean version of ODL?
