PCEP Error when setting KA on Xrv to 255
helen11
When I set the keep alive on XRv router to  255 the  max values allowed I am seeing the below error message - Attempt To Establish Second Session. PCEP session creation fails with its Peer (Controller). Is this a known XRv issue?? What is the max allowed value??
pce
  peer source ipv4 10.18.132.97
  peer ipv4 10.18.130.92
  keepalive 255
RP/0/0/CPU0:PCEP_R5#show mpls traffic-eng pce peer ipv4 10.18.130.92
Mon Nov 27 19:01:25.154 UTC
PCE Address 10.18.130.92
State Idle
Precedence 255
Learned through:
  Static Config
Sending KA every 25 s
Time out peer if no KA received for 255 s
Tolerance: Minimum KA 10 s
KA messages rxed 2588 txed 19368
PCEReq messages rxed 0, txed 0
PCERep messages rxed 0, txed 0
PCEErr messages rxed 1, txed 69
  Last error received:  Type 1 Value 1
  Last error sent:  Type 9 Value 0
PCE OPEN messages: rxed 1068, txed 998
PCEP session ID: local 231, remote 44
Average reply time from peer: 0 ms
Minimum reply time from peer: 0 ms
Maximum reply time from peer: 0 ms
0 requests timed out with this peer
RP/0/0/CPU0:PCEP_R5#RP/0/0/CPU0:Nov 27 19:01:11.875 : te_control[1050]: DBG-PCE-KEEPALIVE[10]: te_pce_process_timers:563: te_pce_process_timers: peer (10.18.130.92) sending KA after 25s
RP/0/0/CPU0:Nov 27 19:01:11.875 : te_control[1050]: DBG-PCE-KEEPALIVE[10]: pce_tx_msg:3580: Sending Keepalive to 10.18.130.92.
RP/0/0/CPU0:Nov 27 19:01:11.875 : te_control[1050]: DBG-PCE-KEEPALIVE[10]: pce_transmit:1753: peer 10.18.130.92 (fd 147) msg_type = Keepalive priority 0
RP/0/0/CPU0:Nov 27 19:01:13.205 : te_control[1050]: DBG-PCE-DETAIL[10]: te_pce_walk_peer_dbase:996:     Closing Peer: 10.18.132.97 --> 10.18.130.92
RP/0/0/CPU0:Nov 27 19:01:13.205 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_tx_msg:3585: Sending Close to 10.18.130.92.
RP/0/0/CPU0:Nov 27 19:01:13.205 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_transmit:1748: peer 10.18.130.92 (fd 147) msg_type = Close priority 1
RP/0/0/CPU0:Nov 27 19:01:13.325 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_tcp_close:294:     Cannot delete static peer 10.18.132.97 --> 10.18.130.92
RP/0/0/CPU0:Nov 27 19:01:13.325 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_lspmgr_start_lsp_timeouts_ex:836: LSPMgr started timer(s) for LSP 9 (PCEP_R5_t8) (delegation 180, cleanup 0)
RP/0/0/CPU0:Nov 27 19:01:13.325 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_lspmgr_start_lsp_timeouts_ex:836: LSPMgr started timer(s) for LSP 10 (PCEP_R5_t9) (delegation 180, cleanup 0)
RP/0/0/CPU0:Nov 27 19:01:25.414 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_process_peer_sockets:496: pce_process_peer_sockets: Condition 1, Peer state = 3, fd = 147
RP/0/0/CPU0:Nov 27 19:01:25.414 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_process_rx_msg:8278: Open msg, hdr size=[28], bytes read=[28]
RP/0/0/CPU0:Nov 27 19:01:25.414 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_enqueue_simple_error_msg_with_srp:8692: Enqueuing a simple error 9-0 (Attempt To Establish Second Session) message to 10.18.130.92, state = 4 send_and_close Y
RP/0/0/CPU0:Nov 27 19:01:25.414 : te_control[1050]: DBG-PCE-DETAIL[10]: pce_enqueue_simple_error_msg_with_srp:8729: size: [12] length: [12]
eckelcu
The range should be 0 to 255.
Note, however, that it is also possible to configure the pce tolerance keepalive value.
Example:
RP/0/RP0/CPU0:router(config-mpls-te)# pce tolerance keepalive 10
(Optional) Configures a PCE tolerance keepalive value (which is the minimum acceptable peer proposed keepalive).
Could it be that the peer has this set to 25 seconds?
