Python: Numbering doesn't work as expected
write_erase
Visitor
This code almost perfect, however the 2nd numbering is not working as expected.
user@linux:~$ cat ip.txt
10.1.1.1
10.2.2.2
10.3.3.3
user@linux:~$
script.py
from netmiko import Netmiko
with open('ip.txt') as f:
print('List of Hosts')
print('-' * 13)
for x,y in enumerate(f.read().split(), 1):
print(f'{x} - {y}')
f.seek(0)
ip_list = f.read().splitlines()
print('\nNo Hostname \t IP Address')
print('-' * 27)
for ip in ip_list:
net_connect = Netmiko(ip=ip, device_type='cisco_ios', username='u',password='p',secret='p')
hostname = net_connect.find_prompt()[:-1]
print(f'{x} {hostname} \t {ip}')
Output
user@linux:~$ python3 script.py
List of Hosts
1 - 10.1.1.1
2 - 10.2.2.2
3 - 10.3.3.3
No Hostname IP Addressi
3 R1 10.1.1.1
3 R2 20.2.2.2
3 R3 30.3.3.3
user@linux:~$
Desired Output
List of Hosts
1 - 10.1.1.1
2 - 10.2.2.2
3 - 10.3.3.3
1 R1 10.1.1.1
2 R2 20.2.2.2
3 R3 30.3.3.3
user@linux:~$
 UPDATE
As advised by ngkin2010, the IP addresses have been stored into an list instead of being read twice.
Here is the updated code
ip_list = f.read().split()
print('-' * 13)
for x,y in enumerate(ip_list, 1):
print(f'{x} - {y}')
print('-' * 27)
for x, ip in enumerate(ip_list, 1):
ngkin2010
Level 10
Level 10
....print('List of Hosts')
....print('-' * 13)
....for x,y in enumerate(f.read().split(), 1):
........print(f'{x} - {y}')
....f.seek(0)
....ip_list = f.read().splitlines()
....print('\nNo Hostname \t IP Address')
....print('-' * 27)
....for x,ip in enumerate(ip_list,1):
........net_connect = Netmiko(ip=ip, device_type='cisco_ios', username='u',password='p',secret='p')
........hostname = net_connect.find_prompt()[:-1]
........print(f'{x} {hostname} \t {ip}')
 Btw, why would prefer to read the file twist while not just store the IP addresses into an list?
ngkin2010
Level 10
Level 10
....print('-' * 13)
....f.seek(0)
....print('-' * 27)
Thanks for helping. I'm new to Python btw. That was the easiest solution that I can think of.
Btw, I've modified the code and store the IP addresses into an list instead of reading it twice.
    print('-' * 13)
        print(f'{x} - {y}')
    print('-' * 27)
If there is any room for improvement, please let me know.
Manoj Papisetty
as far your code is concerned, 'x' value is already 3 by the end of first "for" loop. And the second loop has no 'x' for enumeration and so the value stays at 3.
