RESTCONF GET Issue with IOS-XE 5Gig Interfaces
EhsanVessal
Hey all, I'm having this issue with making REST GET calls. When I make a call in Postman or Python to this device, it works fine:
https://host/restconf/data/ietf-interfaces:interfaces/
        "name": "FiveGigabitEthernet1/0/1",
        "type": "iana-if-type:ethernetCsmacd",
        "enabled": true,
        "ietf-ip:ipv4": {},
        "ietf-ip:ipv6": {}
        "name": "FiveGigabitEthernet1/0/10",
        "enabled": true,
        "ietf-ip:ipv4": {},
        "ietf-ip:ipv6": {}
        "name": "Vlan219",
        "type": "iana-if-type:l3ipvlan",
        "enabled": true,
        "ietf-ip:ipv4": {
          "address": [
              "ip": "10.46.219.60",
              "netmask": "255.255.255.128"
When I modify the REST URI to focus on a specific VLAN interface, it works fine too:
  "ietf-interfaces:interface": {
    "name": "Vlan219",
    "enabled": true,
    "ietf-ip:ipv4": {
      "address": [
    "ietf-ip:ipv6": {}
However, if I want to make a GET call to a specific physical interface, it doesn't work for some reason:
  "errors": {
    "error": [
        "error-message": "uri keypath not found",
        "error-tag": "invalid-value",
        "error-type": "application"
The URI is calling the very first Fi1/0/1 interface that you saw in the very top output. Am I calling the interface incorrectly trying to get its output? What am I doing wrong here?
EhsanVessal
Ok figured it out. You have to replace forward-slashes in a call "/" with "%2F", which is needed for URL encoding and is an ASCII character reference. Here is the final correct call:
https://host/restconf/data/ietf-interfaces:interfaces/interface="FiveGigabitEthernet1%2F0%2F10"
    "enabled": true,
    "ietf-ip:ipv4": {},
    "ietf-ip:ipv6": {}
EhsanVessal
Forgot to add, I'm running this on a Cisco 9300 on 16.9.5 code.
EhsanVessal
Just wanted to bump this and see if anyone had insights?
EhsanVessal
    "enabled": true,
    "ietf-ip:ipv4": {},
    "ietf-ip:ipv6": {}
