Unable to re-provision a sda device after deletion
kara
I have a SDA fabric with 2 BRs and 2 Edges. In order to simulate SDA device provisioning flow for Customer,  decided to delete Edge 2 from fabric, then re-provision back to fabric following the DNAC User guide.
To delete Edge 2, we
1. Remove the node from the fabric as edge node
2. Remove associated port assignment
3. Delete the device from Inventory, but did not select the option for configuration clean up
We then attempt to re-discover the node, however, the discovery process unable to contact the node properly. There has been no change to the DNAC device credential and the same credential could be used to discover other nodes in the fabric
Specifically, the Edge2's physical link IPs can be discovered,  (192.168.236.69/70), but not the 192.168.236.70 Loopback as fabric node router ID.
At BR1, show cdp neigh also shows the edge 2 device is connected.
Would like to know what been missing in order to re-provision the edge node back into the fabric? Tks.
5 Replies 5
It seems weird; I do not know why it is not able to re-discover. Did you make any change on the configuration? The IP address on the physical address (192.168.236.69/30) and the loopback address (192.168.236.70/32) are overlapping. Is that changed recently?
HTH,
Meheretab
Hi Meheretab,
Nothing changed on the config.....the Edge node was simply removed form DNAC GUI by
1) remove device from fabric
2)delete device from inventory
as trying to simulate user work flow.
I logged onto the BR nodes (1&2), and found the interfaces config connected to the Edge2 are all erased, hence even ping failed. Just wondering is that normal expected behaviour?
Sincerely,
kara
Hi Kara,
Thank you for the additional information! I personally have done brown field deployment and I do not experience the issue you mentioned. Did you use LAN Automation? Or, did you configure Edge2 underlay manually?
HTH,
Meheretab
Hi Meheratab,
Managed to track the original lab owner and the lab believed was setup using LAN Auto then. Somehow the BR's corresponding interface conf was removed when edge device was deleted. Needed to re-enter manually and re-discover to pull the edge device back in. Tks.
-Kara
