yang module for interfaces
sqambera
Level 4
Level 4
I'm new to network programmability. I am wondering is there a module that can provide the information same as "show ip interface brief" meaning interface names and ip addresses. The module I have been referencing to provides unwanted detail:
Cisco-IOS-XE-interfaces-oper:interfaces
Qamber
balaji.bandi
you can use python if that work for you ?
BB
Try
# import requests, jason and sys
import requests
import json
import sys
#device details
HOST = 'ios-xe-mgmt-latest.cisco.com'
PORT = 443
USER = 'developer'
PASS = 'C1sco12345'
# disable urlib3 warning
requests.packages.urllib3.disable_warnings()
#main function using restconf to show the status of device interface and print results in json
def main():
    # create a main function using restconf
    url = "https://{}:{}@{}:{}/restconf/data/ietf-interfaces:interfaces".format(USER, PASS, HOST, PORT)
    headers = {'Content-Type': 'application/yang-data+json'}
    response = requests.get(url, headers=headers, verify=False)
    print(response.status_code)
    # print the results in json format
    print(json.dumps(response.json(), indent=4))
# Call the function main() and exit giving the system the return code that is the result of main()
if __name__ == '__main__':
    sys.exit(main())
Will print the following
∙     "ietf-interfaces:interfaces": {
∙         "interface": [
∙                 "name": "GigabitEthernet1",
∙                 "description": "MANAGEMENT INTERFACE - DON'T TOUCH ME",
∙                 "type": "iana-if-type:ethernetCsmacd",
∙                 "enabled": true,
∙                 "ietf-ip:ipv4": {
∙                     "address": [
∙                             "ip": "10.10.20.48",
∙                             "netmask": "255.255.255.0"
[snip]
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
