faayvaz
Dear All,
Referring to "NSO Access Control - Role-based and Resource-based Access" session, which was presented in Cisco NSO Developer Days 2020 (Virtual) event, I share the external authentication script that was used for the actual NSO demonstrations shared within the presentation and follow-up discussions.
NSO Access Control – Role-based and Resource-based Access On-Demand Session
https://youtu.be/hnoueH0vI8k
Please let me know if you will have any comments/questions on it.
Kind Regards
Fatih Ayvaz
Solutions Architect, Cisco CX
2 Comments
faayvaz
#!/usr/bin/env python
import sys, re
# please modify below as per your NSO_LOG directory
f=open("<some_dir>/external-authentication.log", "a+")
f.write("\nCalled\n")
credentialstring = sys.stdin.readline()[:-2][1:]
if credentialstring.endswith(';'😞
newcreds = credentialstring[:-1]
else:
credentials = newcreds.split(';')
stringcount = len(credentials)
if stringcount == 1:
token = credentials[0]
elif stringcount == 2:
user = credentials[0]
password = credentials[1]
elif stringcount == 5:
extraip = credentials[1]
extraport = credentials[2]
extracontext = credentials[3]
extraproto = credentials[4]
else:
f.write("Number of fields in stdin is not recognised:\n" + "counted: " + str(stringcount) + ": in: " + newcreds + "\n")
exit()
f.write("Token based authentication\n" + "TOKEN: " + token + "\n")
if user == 'tokenfatih':
print "accept group_ayvaz 1000 1000 /var/python/homes/ fatih\n"
elif user == 'tokendemouser1':
print "accept demogroup1 demogroupN 1000 1000 /var/python/homes/ demouser1\n"
f.close()
exit()
f.write("External-validation with extra fields(token;ip;port;context;proto)\n")
f.write("TOKEN: " + token + ": IP: " + extraip + ": PORT: " + extraport + ": CONTEXT: " + extracontext + ": PROTO: " + extraproto + "\n")
if token == 'tokenfatih':
elif token == 'tokendemouser1':
f.close()
exit()
else:
f.write("\n" + "user: " + user + ": password: " + password + "\n")
#f.write("\n" + "user0: " + user0 + ": password0: " + password0 + "\n")
if user == 'fatih' and password == 'cisco':
print "accept group_ayvaz 1000 1000 /var/python/homes/\n"
elif user == 'demouser1' and password == 'cisco':
print "accept demogroup1 demogroupN 1000 1000 /var/python/homes/\n"
elif user == 'demouser2' and password == 'cisco':
print "accept demogroup2 demogroupN 1000 1000 /var/python/homes/\n"
elif user == 'demouser3' and password == 'cisco':
print "accept demogroup3 demogroupN 1000 1000 /var/python/homes/\n"
elif user == 'demouser4' and password == 'cisco':
print "accept demogroup4 1000 1000 /var/python/homes/\n"
else:
print "reject\n"
f.close()
exit()
faayvaz
import sys, re
if credentialstring.endswith(';'):
else:
else:
    exit()
    f.close()
    exit()
    f.close()
    exit()
else:
    else:
        print "reject\n"
    f.close()
    exit()
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
