rogaglia
Recently, new classes were added to NSO Python API that makes it easier to play with commit/re-deploy parameters. Let me show you some examples on how you can make your life easier:
Setting CommitParams:
General Steps:
1) Create RW Maapi session and transaction handler:
m = ncs.maapi.Maapi()
m.start_user_session('admin', 'system', [])
trans = m.start_trans(ncs.RUNNING, ncs.READ_WRITE)
2) Create params instance of CommitParams class:
params = trans.get_params()
3) Depending on the objective you format your params object. See examples bellow
4) Optional: validate params:
print(params)
5) Apply and capture result:
result = trans.apply_params(True, params)
Example of possible parameters:
a) Commit dry-run outformat native use-lsa:
params.dry_run_native()
params.use_lsa()
print(params)
Output: CommitParams(dry-run/outformat=2 use-lsa=(1145948134, 526283796))
Note: you can add as many as needed but some combinations would not make sense.
b) Commit reconcile:
params.reconcile_discard_non_service_config()
or
params.reconcile_keep_non_service_config()
In [19]: print(params)
CommitParams(reconcile/discard-non-service-config)
or
In [22]: print(params)
CommitParams(reconcile/keep-non-service-config)
c) Commit no-networking:
params.no_networking()
In [27]: print(params)
Outout: CommitParams(no-networking)
d) Commit no-deploy:
params.no_deploy()
In [28]: print(params)
Output: CommitParams(no-deploy)
e) Set the trace-id:
params.trace_id('12345')
In [38]: print(params)
Output: CommitParams(trace-id=12345)
f) Commit no-out-of-sync-check
params.no_out_of_sync_check()
In [41]: print(params)
Output: CommitParams(no-out-of-sync-check)
g) Commit no-overwrite
params.no_overwrite()
In [14]: print(params)
Output: CommitParams(no-overwrite)
How to access to CommitParams from service Code in Python:
Check if it’s a dry-run and other commit parameters:
Note: Please remember to avoid side-effects as a well-known best practice.
Some examples based on the python-and service skeleton service:
class ServiceCallbacks(Service):
    # The create() callback is invoked inside NCS FASTMAP and
    # must always exist.
    @service.create
    def cb_create(self, tctx, root, service, proplist):
        self.log.info('Service create(service=', service._path, ')')
        #Get a Transaction object
        ma = ncs.maagic.get_maapi(root)
        trans = ma.attach(tctx)
        #Get transaction paramters option 1: get_trans_params()
        trans_param = trans.get_trans_params()
        self.log.info('Trans params:', str(trans_param))
        for i in trans_param:
          self.log.info('Trans param: ', _ncs.hash2str(i.tag))
        #Get transaction parameters option 2: using CommitParams class
        self.log.info('Pameters: ', str(params))
            #More methods: See here https://developer.cisco.com/docs/nso/api/#ncs-maapi/ncs.maapi.CommitParams
        if params.is_dry_run():
            self.log.info('Outformat: ', params.get_dry_run_outformat())
            # Outformat: DryRunOutformat.CLI
            #Get TraceID if set northbound
        self.log.info('Trace ID: ', params.get_trace_id())
            # Trace ID: 1234
            # Check if it is reconcile:
        if parms.is_reconcile_discard_non_service_config() or \
            parms.is_reconcile_keep_non_service_config():
            self.log.info('Reconciliation is On')
        vars = ncs.template.Variables()
        vars.add('DUMMY', '127.0.0.1')
        template = ncs.template.Template(service)
        template.apply('check_commit_params-template', vars)
2 Comments
cohult
As part of step 2-4, it can sometimes be useful to traverse the current commit parameters and associated values. The example below shows one way to do so as part of step 2:
    tvs = params._tag_values()
    commit_param_val = ""
    for tv in tvs:
        if tv.v.confd_type() == _ncs.C_XMLBEGIN:
            commit_param = _ncs.hash2str(tv.tag)
            continue
        elif tv.v.confd_type() == _ncs.C_XMLEND:
            continue
        else:
            if tv.v.confd_type() == _ncs.C_XMLTAG:
            else:
                value = tv.v.as_pyval()
                commit_param_val = "{}={}".format(_ncs.hash2str(tv.tag), value)
        print("{} {}".format(commit_param, commit_param_val))
ksj
Visitor
This is quite helpful as I refactor a python action package from NSO 5.4. I do have a question though. In the past we could retrieve a dry-run using root.services.commit_dry_run. It's unclear how to retrieve the dry-run from the docs, though I am probably missing something right in front of me.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
