Shaun Roberts
4-24-14 Update, version 1.0.0.3: Code cleanup around archiving.
This is an extension to my Automation Function Tools pack in this same community. It gives you a process which will go through your process queues (that are a part of the AFT pack) and clear them out. You only need this if you are using the process queue functions I wrote.
